- Joined
- Oct 1, 2011
- Messages
- 459
- Reaction score
- 239
- LOCATION
- SoCal
Preparing to purchase a new TM. Going with Minn Kota Terrova (no transducer...only remote and iPilot)
Spoke to MK today. Here are MK answers to my questions about thrust, volts, and shaft length....
Thrust - MK: 2# for every 100# of boat weight (including motor, gear, passengers, etc). My 2023 Tracker Pro Guide V16 SC weighs about 1200#, plus gear people = 2000#
That would equal 40# of thrust. That seems VERY low!! Maybe that's why my boat came equipped with a 42# thrust, 12V, 54" shaft TM!!!
Volts - MK: If you use a 24V TM with 80# of thrust on my boat, I may experience difficulty in boat staying anchored using iPilot....as boat would be too light for the amount of thrust. It was a technical explanation, but it made believe that you can "overthrust" in the selection of a TM. I see most people with a similar sized and weight boat opt for the 24V 80# thrust when upgrading. MK claimed it can be too much thrust considering the formula they use for thrust selection. I mentioned that perhaps people select the 24V for longer run times...MK stated you can run 2 12V batts in parallel for added run time.
Shaft Length: - My boat came equipped with a 54" MK Powerdrive. Basic model with only a foot pedal. No iPilot. It should be correct length. MK: Add 20" to distance from bow mounting location to waterline. Since my new boat has not been used, I have no waterline!
Questions....Anyone with the same or very similar boat and specs of mine (weight, gear, deep V hull, etc):
TM size?
Shaft Length?
Thrust?
Did you select 12V or 24V and why?
Thrust amount and Why?
I am most intrigued by the thrust and 12V VS 24V discussion.
Thoughts?
Thanks!
TM size?
Shaft Length?
Thrust?
Thoughts?
Thanks!
