pros and cons. cc vs sc vs ss
hipster dufus
Post by hipster dufus »
pondering selling my 1648 tiller. wondering about the usefulness of center console vsside console vs stick steer. anyone own all 3? opinions wanted. thought my tiller was gonna b my last boat. like i said pondering,
matt.probuilder
2
Post by matt.probuilder »
Also question I'd like to learn more about. I enjoy my tiller but at the same time I think a stick steer would be very efficient in a lot of ways.
Sent from my SM-N900V using Tapatalk
Stumpalump
6
Post by Stumpalump »
I've had all three. All have pros and cons. Best handling and room goes to the tiller. In a small boat it's the most fun and my favorite of the three. Problem is you can't stand and hang on but with your body in the stern the ride is smooth enough to sit. It can get tiring. It's not cool and lumps you in with the dingy crowd. With one hand on the engine and one on the hull you are locked in for best control.
The side console is nice because it's tucked against the side and takes up little room. Port starboard balance needs to be considered but that's obviouse. Look for ones that you can still stand while operating the boat. The fore and aft weight is a concern as well so look for side and CC that don't put the wheel too far foward. A lot of the newer ones put the driver too far foward to compensate for a heavy 4 stroke. If it looks too far foward then it is and you will take a beating over wakes. Stick steer sucks according to Rich so that's good enough for me.
Center console like I have now is the best if you have the room of 17-18' or above. You can walk all the way around it to fight a fish or dock the boat. Generally you stand to see really well and absorb shock. Port/Starboard balance is fantastic with minor shifts of your stance. You are mostly out of the wind if you sit and most will have room to sit two side by side so you can talk and balance the weight aft. If a CC is just physically going to take up the room you need to move foward then look to the side console. Both center and side are a waste of space, weight and complexity in anything smaller than an extra large and roomy 16 footer.
1991 18' Valco Bayrunner Evenrude 48 SPL
Arizona
Tinny Fleet
3
Post by Tinny Fleet »
I've also had CC, SC, but not a stick steer. Of them the most comfortable to fish out of is my 18' center console, but only because of the reasons a previous member stated which was roominess to walk around. However my current major project is a 16' tiller boat, which could go to CC or Stick depending on how it fishes. The reason for the smaller boat is that it is an easier size to handle the older I get. I plan to have it for a while.
Tinny Fleet
surfman
Post by surfman »
I have a friend that has a 15' Carolina Skiff, he went with the center console and he likes it, I don't, hard to move from the front of the boat to the rear the boat is too small IMO for a CC. So what Stumpalump says covers it pretty well, size matters to me.
WALI4VR
3
Post by WALI4VR »
B 4 u condemn a tiller drive a couple. Very comfortable to drive and if boat control is important to u can't b beat. On rivers lakes big water makes no difference. I can hold mine in a 3 ft diameter circle with a 5 to 10 mph current on top of a 20 mph cross wind. Plus the whole rest of the boat is good 4 whatever u want to do with it! Have fun.
ps learn to run a tiller with your left arm and hand right from the get go.
Sent from my XT1650 using Tapatalk
LDUBS
3
Post by LDUBS »
Oops -- delete. Sorry :(
Have Rod - Will Fish
LDUBS
3
Post by LDUBS »
For 1) my small boat, 2) my shoulders, and 3) the kind of fishing I do 99% of the time (trolling), a side console works best.
earl60446
Post by earl60446 »
I have a side console on my 16, it is ok but it takes up a lot of room and sitting on the side means the boat leans to the side.
I used to have a tiller and I wish the boat I have now was a tiller. Always keeping my eye out for the parts to convert my outboard.
Tim
16ft 1989 Fisher SV-2 w 1988 48hp SPL Johnson "CIGAR BARGE"
(engine looks like a wreck but runs great)
Used to have 1972 14ft Lund w 1977 15hp Mariner
(engine looked great but always ran marginal)
XLINE SPORTSMANS CLUB
JL8Jeff
6
Post by JL8Jeff »
I prefer to stand while under way so a center console is my preference. I've had 4 or 5 CC boats and liked all of them. I can read the ripples ahead of me easier while standing. But there can be limited space to get around them depending on the size of the boat. I have a Lowe 1652 and the center console is pretty narrow (about 19" wide) and there is enough room to get around each side for an average size person. A 1648 could get tight and I think a 1660 is the best size smaller boat for a CC.
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
onthewater102
6
Post by onthewater102 »
I put a SC on my little 1436 so the kids could drive it, which has been fun for them but a waste of space even tucked as tight to the side as possible.
Running rivers and reservoirs I really like a high stance for visibility in case of debris in the water - can't do that well with the side console. I really like my friend's 1652 CC for that reason so I think I'd prefer a center but my boats are too narrow (1436 and 1648.) Unless I build a very skinny CC for the 1648 that isn't much wider than the steering wheel I'm probably going to end up leaving it as a SC.
2002 Alumacraft 1436LT (SOLD)
RiverBottomOutdoors
Post by RiverBottomOutdoors »
One thing that is a must for CC on small boats is a good grab rail.
DaisyCutter
3
Post by DaisyCutter »
I'm 6'1" and 210 lbs, and I have to shoehorn my legs into any side console that's in a boat less than 19', and even then some are a PITA.
I have ample legroom with a tiller steer.
Yeah, the tiller swings, but I have urangutan arms too so it's not a problem.
Some of them consoles have the bottom of the steering wheel 4" from the front of the seat... Sized for a 1st grader.
turbotodd
Post by turbotodd »
No doubt about the consoles. I'm 6'7 and about 240 currently, so there's not a single console out there that I can comfortably sit in/under/behind. I have run 4 major kinds. CC. SC. Tiller. And stick.
CC is good for bays and flats but you lose half of your boat to the console. So if you have to move around any, you have to walk around the console. That's one reason they're usually larger (20'+) boats.
SC is what most tins are, at least the ones that have consoles. They're better than CC in my opinion, and a good option for those who want to comfortably sit for a long distance boat ride. That is, of course, if you can comfortably sit. I can't. Or at least I haven't found one that I am comfortable with-yet.
Tiller is more for smaller boats that need maneuverability. People laugh at me sometimes when I show up at the lake with my little 15' tin/tiller steered 25hp motor (sometimes everyone else at the ramp has 10x or more the HP), but they usually shut up when I come back an hour later with a cooler full of crappie (limit here is 40 per person). IF the GF goes, we can fill the freezer, and quickly. But we can get back in that creek that most won't go.
Stick steering is for the crappie/panfish angler mostly. It enables a person fishing alone to sit in one seat, fish, then start the outboard and motor to a different spot-without having to leave the front seat. I personally don't care for stick steering but I haven't gotten used to it either. I suppose if I ran one/fished out of one long enough I may get used to it. Or maybe not.
There's also a guy local that has a one-of-a kind boat. It's a console turned sideways. Helm is facing to the side, on the right side of the boat. It's weird, but it's the best of both a stick steer and a side console; not a lot of room is lost and it allows the operator to sit in the one seat. I have never seen another one like it; and I can't remember who built it. Maybe G3. I don't remember. Has a F70 Yamaha on it which purrs like a cat; honestly the quietest motor I've ever heard. Take the cowling off and you can hear the injectors ticking. Put it back on and you hear pee water hitting the lake surface, and nothing else.
