thill
Thanks. Yes, we caught a number of redfish (red drum) along with bluefish, flounder, trout and some other species. A great day on the water.
![Resized_20240529_092429.jpeg Resized_20240529_092429.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/102/102863-ec59b91a5e93ed0cf222cd4118072093.jpg)
![Resized_20240528_082808.jpeg Resized_20240528_082808.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/102/102864-96d4f69a22d8b6708e41b0c59be98fb1.jpg)
![Resized_20240528_080833 (1).jpeg Resized_20240528_080833 (1).jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/102/102865-89b696442945666bededf7bba1528179.jpg)
![Resized_20240528_192356.jpeg Resized_20240528_192356.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/102/102866-4c29044b097ab9ad2fc870378a4b0dc3.jpg)
![Resized_20240528_222458.jpeg Resized_20240528_222458.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/102/102867-fcbfb297d0ad340b40038f329696f63f.jpg)
UPDATE...
I pulled the head off the motor to start testing.
I put everything back together and Viola- She works perfectly again! She just lost contact @ one brush.
I believe the motor WAS getting hot, and that caused a melted spot in the slide that holds the brushes. Fortunately, it lost contact before causing catastrophic damage. I think I got off easily, but learned an important lesson.
From now on, 8.5 is going to be my new top speed except for a minute or two, as needed!
All is well that ends well.
UPDATE...
- The output from the controller to the motor was giving 26V+, so the iPilot controller seemed good. (Thankfully!)
- I then ran power directly to the motor leads... nothing. Problem is down in the motor end.
- I pulled the prop and cap off the motor, and everything looked good. No obvious burned spots on the armature, but I definitely smelled something burned.
- I pulled the brush assembly, and they looked fine. HMMM...
- I tested the resistance of the brushes, and both were good at 0.01 ohm resistance.
- I tested the voltage of the input to the brushes and it was 26V. Not the feed wires.
- When putting the brushes back in, I noticed that one of them was sticking in a spot. Could it be that easy????
