1972 Evinrude 4206
Red12
Michigan
1972 Evinrude 4206. Can anyone point me to the correct fuel line (w/ primer bulb) for this model engine? The attachment at the motor seems to have three prongs as opposed to two, and I have not found one that looks like it would fit.
Thank you
Let me look that up for you
That comes up as a 1972 4hp. Should take the standard OMC single line fuel hose and primer bulb. Should have points and condensers in it as well.
Not sure about your three prongs unless you are counting the cast aluminum boss that helps align and protect the female fitting when attached to the engine. You shoulld have the blunt fuel barb and the tapered ended alignment barb other than the boss mentioned above.
