1987 Alumacraft Super Bandit Restoration
You have done a great job so far, from what I can see. Just work on it when you can.
The end results are the biggest thing. Safe and solid, no matter how long it takes. Thanks for sharing!
Before you get too far you might want to change the trolling motor so the head does not stick out past the side of the boat. Don’t want that banging against docks.
It doesn't quite stick out past the side. It's just barely inside the rail but it is inside. I was concerned about that when mounting it. I mounted it by myself which isn't too bad but it was hard to get it to balance on the bow plate. It's a heavy trolling motor. Made sure to mark and measure multiple times
