Need Some Advice On Controls
Lynn
Petaluma California
I have a 16 foot Klamath center console with a 35 HP Johnson and whole put crabbing today I broke the side mounted shifter throttle control. Actually just the shifter but I am looking for recommendations for a starboard side mount?
Do I need new cables?
The current cables seem okay other than the reverse handle snapping.
The original post should have read 'while out crabbing" not "whole put crabbing" big fingers I guess.
Anyway it's the nylon connector that fits on the Morse cable that is bad not the control box.
Anybody have a part number or supplier for the white nylon piece in the photos?
    194.5 KB
    185.8 KB
It's all about the terminology.
The nylon piece is called a "case guide".
I found it by using the wrong terminology in a Google search for shift control box kit.
Once I had the name right I found 2 pieces that should work.
    230.3 KB
    122.7 KB
