I wouldn't ...
Take your time, use a new PRICK punch (60-degree included angle at the 'tip') to carefully hit the center of each rivet, then use a good 3/16" (cobalt preferred) bit to drill them out. Always keep the drill square to the surface being drilled. If the head stays on the hull, whack it off with a sharp chisel set at a low angle. One tip, mark the enter of each rivet with a fine point Sharpie marker so you know exactly where to 'hit'; also makes the work go faster!
See here for the special brazier head tool and a bucking bar:
https://tinboats.net/forum/viewtopic.php?f=3&t=41248&p=419799
Now here's my 11-year re-riveting 'her' 12' boat using all of the tools and knowledge above, so if she can do it - then so can you
https://tinboats.net/forum/viewtopic.php?f=3&t=41042
Rivet, buy the 1100F alloy ones from Jay-Cee Rivets online, buy a little or buy in bulk!
https://www.rivetsonline.com/?gclid=CjwKCAiAudD_BRBXEiwAudakXyxt3Jjt_9H3VXODRQbrJSlLWJ_lDVj6xFFWzrODjOV1jYCyG1y2EBoCTS4QAvD_BwE
