EasternEasy
I cut and drilled the new plywood pieces for the transom today. I just went with a straight up replacement - same size, same shape, but now I'm thinking….
Have a look at the pics. I've just put a couple of bolts through to hold it in place for the photos.
Instead of the outside plate, I'm thinking of cutting a piece that has extensions on either side along the top. You get the idea from the pic with the piece of wood clamped on the left. My main reason for considering this is then I would be able to fasten both bolts for each handle through two pieces of 3/4 plywood. If I stay with just the plates, the upper bolts of the handles only go through the aluminum transom and the inside transom strip.
My buddy says stick with the KISS priniciple and just replace what was there and get on with it. I'm somewhat inclined to agree with him on the basis of that's the easiest, cheapest, lightest, and fastest way to do it, but think the extensions would make the whole transom a bit stiffer, and it looks a bit better. I also have to figure out a way to get a transom mounted trolling motor and a Johnson 9.9 on the back at the same time, and though I don't have any idea how to do that, I thought the extra wood on the back might come in handy.
Any thoughts or suggestions on either issue welcome, as I haven't got a clue what I'm doing, but I'm having fun.
Easy
Easy
