14' deep V sylvan mod
Thanks Flipte, do you have pics on how how mounted your 'legs'? I'm having a hard time figureing out how best go about putting the front deck on....... Since my boat is a V bottom, do you recommend the legs going to the bottom of the boat at an angle? or striaght down to each side of the boat?
My boat is a fiberglass deep v but it has a flat bottom. See my thread, i have some pics uploaded of the legs. I attached the legs (2x2) to the bottom of the casting deck with L-brackets then a flat 2x4 across the boat floor. I would try to put the 2x4 on the stronger points of the boat floor. leave the legs 1/4" maybe less longer than the height needed. then you can shim it down if your deck raises too much. play with it so that you have even weight spread over the boat. Any other questions dont hesitate to ask but put it on my thread that way were not hijacking this one. :p
