14 ft Starcraft Mariner help
sprunx
First off let me start by saying I am new here but have been lurking for a week and have found great info. I acquired a 1970 Starcraft mariner bare hull about 2 years ago and a few months after that did a quick resto. It wasn't exactly what I wanted at the time but getting it in working useable order was more important at the time. I replaced the transom added a deck and did some other little thing like bench seats and what not. I didn't put a whole lot of research into what I was doing at the time so now I'm looking to change it up and do it properly. I previously used 3/4 plywood with a single stringer down the center as a deck before but I'm looking to redo it with aluminum in order to lighten it up and make it a "forever" boat with no wood to delaminate or rot. I also want to make an anchor locker/ platform in the front and split bench seats in the rear as the boat is set up for a tiller motor. My biggest question is what is the best way to rig up stringers and what thickness aluminum sheet or diamond plate should I be using to get the most support without excessive weight. I have seen many flat bottom Jon boats on here but laying a sheet of aluminum across the flat supports is a little different than dealing with a v hull. Any help would be greatly appreciated and yes I have used the search feature and seem to only find many flat bottoms.
Also what would you guys recommend for sealing the bottom rivets with. I have no issue with any of them leaking, the boat stays dry as bone but would rather be safe than sorry.... Oh and the boat will almost always be used in saltwater if that makes on a difference on anyone's input. Thanks in advance for any advice. It's greatly appreciated
Welcome, good luck with your project. Please post lots of pictures! Its great that you don't have any leaks. You do not have to do anything to the rivets but if you feel the need I would use a product called Gluvit or 3M 5200 on the inside of your boat.
