Jonboat Jerry said:
Killer work Dobsonfly, the transom and seats turned out great. If you can stand it, I would not cover the seats.
Bright work shows up beautifully on a restored boat and it's easier to clean too. Great job! =D>
Despite how good the seats look from a distance in the photo, I didn't really treat the seats with as much care as I did the transom. I said to myself, as I was putting down the varnish "I am covering it up anyway" and so any bug that flew its way in is now preserved by a nice few heavy coat of gloss, not to mention the imperfections I didn't bother sanding out and marks left from measuring and layout. So I covered the seats still. I was still pleased with the results.
Carpet is from Home Depot, it is outdoor for deck porches and pool areas, has a UV protectant. I spent around $40 to do this carpet job (carpet $20, SS Staples $11, glue $10). Used water proof glue and stainless steel staples to secure it with. All hardware bolting the seats in is stainless steel button head cap screws with stainless steel nylock nuts (again use antiseze).
I saved the old transom cut out to use as a template to bend the new transom trim piece. I did cheat a little vs the original design. I cut and welded the other straight pcs on mine, because I started at one side to start bending this piece DON'T DO THAT! I would recommend marking center on your old transom cut out piece as well as the aluminum trim piece. Align the two center marks, clamp like I did in the photo and then bend the piece. Basically I ended up too long on one of the legs, so I cut it and welded each side on instead. Anyway that's just my 2 cents for those ordering the section I did from Mirrocraft for the transom. Also you will need some tin snips to relieve like the original for the sharp bends.
