14' V-hull mods harbercraft
Kawartha92
Hey guys I've been using this site for a while before I picked up my boat, so much good information on this site it's awesome. Anyways the boat I picked up is a 14' vhull harbercraft, it's got a 20 hp mercury from the 80s I believe and an old rusty trailer. This is the first boat I've owned and the main problem I'm having is its leaky! I've filled it up with water and marked some leaks. I will get pictures up to show you soon. I picked up some of the 3m 5200 and plan on using it just wanted to hear some input. Once I get the leak fixed and I was thinking of putting in some decks just not really sold on a layout yet and would love to hear what some of you guys would do with it.
So if anyone sees a nice layout in there head, I'd love to hear them, pretty much open to any suggestion
    186.9 KB
    208.4 KB
    202.1 KB
Hi Kawartha92. Cool new toy you've got there. The beauty of aluminum boats is that you can do pretty much anything you want to them with pretty basic tools and techniques. There are really only a few rules to remember when it comes to tinnies; 1.) NEVER use pressure treated wood as it will cause pitting in any aluminum it comes in contact with. Instead, use high quality, exterior grade plywood and seal it. You can use spreadable 2-part epoxy, Spar Urethane, or even several coats of good exterior grade paint such as Rustoleum Professional Oil Based Enamel. 2.) To mount it to the hull you'll want to use aluminum rivets and/or stainless steel hardware dipped in 3M 5200. 3.) You can do any framing within the hull using 2"x2" non-pt lumber and/or aluminum angle and tubing. That's really about it. The rest is simply a matter of time, money and creativity.
As for the current leaks, 5200 isn't the best ting to use. Instead you'll want to either rebuck the current rivets, drill them out and replace them, or simply paint the interior seams of the boat with a product such as Gluv-it. You never want to repair anything below from the outside of the hull, always from the inside out (i.e. seal interior seams rather than exterior). With the exception of epoxy products, which you can order online or buy at boat shops like West Marine, you can get everything you need at any Lowes/HD.
With regards to your layout, that will mostly depend on what type of fishing/boating you do. I have an old '59 vintage, aluminum runabout that I converted to a flats skiff, while other folks have converted skiffs into bass boats and cruisers. It mostly just depends on what you like best. The first thing to decide on is if you're going to use a helm (steering wheel with controls), or use a tiller to run the motor. If you use a tiller, I would suggest a tiller extender and grab bar, both of which you can make. If you're going with a helm, I would suggest a small center console, but others like a side console arrangement.
Hey thanks for the reply, I was thinking of taking out the middle bench and putting a flat deck in between the benches, and maybe a storage compartment in the back and front, I'm not looking to make this into a huge project just some little editions that will make it more suitable for fishing, if I took the middle bench out would that effect it's overall stabilit? Also how do I remove these benches with the kind of rivets it has?
    164.4 KB
So I drilled out the rivets on the top of the bench and the side, it seems there is something under neath the bench still holding it in place, anyone have this problem as well or know a solution on how to get it off?
So I was finally able to get the bench out, finally feels like I got the first thing done and out of the way. If I I was going to use gluvit for the inside of the hull would the surface need to be right down to the aluminum?
    219.3 KB
