J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 9, 2016 #1 Hey all, this is my first build. I've been all over this site getting ideas from the the great minds and I'm finally ready to post some pics. I'm about half way done as of today.
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 9, 2016 #2 Finally made it home. 3 Hour drive with a twisted axle and mismatched tires, plus no lights. Attachments uploadfromtaptalk1457583912435.jpg 25.9 KB
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 9, 2016 #3 View attachment 1 Covered in flex seal! Pretty good size Crack Attachments uploadfromtaptalk1457583971035.jpg 57.7 KB uploadfromtaptalk1457583986748.jpg 38.5 KB
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 9, 2016 #4 More flex seal. But rivets were almost falling out Strip
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 9, 2016 #5 This transom is done, but it's 1" thick. More work already. That was under the rubber seal. The entire boat was sprayed with it.
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 9, 2016 #6 Prying up the old stuff Rotten foam with dead bugs and animals Filled in all the rivets with marine-tex, then Finished the bottom with a can of gluvit and and a paint roller.
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 9, 2016 #7 Three coats of self-etch spray primer. Regular old semi-gloss oil base paint. I thinned it and used it in the harbor freight hvlp purple gun. Worked perfectly. Threw down some bedliner for durability
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 9, 2016 #8 I got bored so I cut out a livewell Maiden voyage Checking for leaks with the wifey. Ops check good!
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 9, 2016 #9 Transom riveted in and mount for bilge pump installed with 5200 Transducer mounted, and sealed with 5200 Decided to rip the back seat completely out and use the space for rod lockers. Attachments uploadfromtaptalk1457584652437.jpg 21.2 KB
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 10, 2016 #10 Playing with the deck frame layout for maximum space and access.
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 10, 2016 #11 Still in progress
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Mar 14, 2016 #12 Going to tie in the rear with rivets and the sides as well. Attachments uploadfromtaptalk1457967299994.jpg 65.2 KB uploadfromtaptalk1457967336624.jpg 46.4 KB uploadfromtaptalk1457967362072.jpg 60.9 KB
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Apr 10, 2016 #13 Playing with the deck frame layout for maximum space and access. Front deck framing done. Checking the fit. Attachments uploadfromtaptalk1460347051530.jpg 53.2 KB
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Apr 11, 2016 #14 Swapped out a cross beam so I can throw in more hatches.
J Jmac80one Member Joined May 3, 2015 Messages 17 Reaction score 0 Apr 15, 2016 #15 Rear deck fitting Front deck fitting
