russ010
They're galvanized and coated with some specail Zmax coating or something (no idea what that stands for). But according to Simpson's website - they are corrosion resistant... but even so, I'm not worried about corrosion
russ010 said:They're galvanized and coated with some specail Zmax coating or something (no idea what that stands for). But according to Simpson's website - they are corrosion resistant... but even so, I'm not worried about corrosion
The strong-ties may be corrosion resistant themselves but that doesn't mean they won't cause corrosion when in contact with aluminum. The two metals should be isolated from each other.russ010 said:They're galvanized and coated with some specail Zmax coating or something (no idea what that stands for). But according to Simpson's website - they are corrosion resistant... but even so, I'm not worried about corrosion
Ouachita said:The strong-ties may be corrosion resistant themselves but that doesn't mean they won't cause corrosion when in contact with aluminum. The two metals should be isolated from each other.russ010 said:They're galvanized and coated with some specail Zmax coating or something (no idea what that stands for). But according to Simpson's website - they are corrosion resistant... but even so, I'm not worried about corrosion
https://answers.yahoo.com/question/index?qid=20080209190027AAKofeG
russ010 said:If you read the last answer on there it says "Zinc is often the metal of choice for the anode"... that is the coating that is on the galvanized brackets and works in the same manner
ober51 said:Sure, if you're paying, lol. I'll see what I can find, but a quick search wasnt productive.
russ010 said:Zinc Chromate causes corrosion?? Funny, I used Zinc Chromate as the primer for my aluminum boat... may be something different, but I don't think it causes corrosion.
Cheeseball said:ober51 said:Sure, if you're paying, lol. I'll see what I can find, but a quick search wasnt productive.
You don't always have to buy it if you are resourceful. If you look you can find good scrap aluminum everywhere.
As for the nylon washers here is what i found on the first page of a Google search:
https://washersusa.com/
https://www.bokers.com/nylon_flat_washers.asp
https://www.microfasteners.com/catalog/products/NYL.cfm
You can also find them at most any hardware store.
