Weldorthemagnificent
- Joined
- Mar 12, 2017
- Messages
- 1,238
- Reaction score
- 62
Nice work!
:LOL2: Thank you!Kismet said:From those of us who do not have "skills," I would like to express my appreciation of the workmanship and artisan patience reflected in your project.
My ex-wife would like to marry you.
Be well in this pandemic, survive the politics that are coming out of it, and find joy each day of your life.
=D> =D> =D>
Does that boat have a splash well?KrazyAboutTin said:Hello there.
I have been watching your work, and I have learned a lot from you. Thank you!.
I have a situation that you might be able to help me with.
I purchased a 1977 16ft StarCraft aluminum boat, and all the plywood wood have to be replaced all around.
I am having trouble removing the plywood from the transom. I have removed all screws and rivets that hold the plywood in place, but I can not take it out. It is stuck somewhere where it touches the aluminum sheet .
I have hammered, pushed it, and used a wrecking bar to no avail.
It seem glued somewhere, but it makes no sense that the factory have glued the plywood to the aluminum sheet.
So, the only think I could think of is that salt crystals were built in between the ply and the aluminum, bonding them together naturally.
I have worked my way in between them with a machete but I am afraid of damaging the aluminum transom.
I also thought of pouring water in between the parts hoping to dissolve the possible deposits of salt and that way been able to remove the plywood.
If you have a chance, please, give me your advice on this matter.
Thanks in advance.
You should start your own thread and post some pics. It may be the splash well drains that are holding your wood in.KrazyAboutTin said:Yes.
Should I remove it?
