Natedog57
Hi,
I'm selling my 16' flat bottom jon (48" on the water, 72" across the top), galv trailer and 50hp Yamaha (2 stroke, trim/tilt).
I've had a lot of work done, and completed a lot myself over the years, below is a brief summary. Feel free to contact me with questions, for more pics, or to take a look at it. It's a great all around boat, flats fishing, gator hunting, duck hunting or bow fishing... Everything is aluminum, except the transom, which is original.
- 4' elevated front deck, nav lights recessed, removable trolling motor mount
- front hatch for semi dry storage
- aluminum floor (.125"), welded subfloor bracing between ribs
- custom center console, battery selector switch/wiring/trays for 2 batterys, switches (nav lights/bilge), 12v outlets, fire extinguisher
- poling platform
- fuel/water separator
- custom fixed jackplate/bracket
- bilge pump (hull has Wearlon Wetlander coating, but has very small leak)
- 9 gal poly fuel tank mounted under front deck
- newish paint, looks very good
Engine has approx 15 hrs on new rings/pistons/gaskets/carb job. Runs good, SS prop, light load will run 35+, running premix non-eth.
Asking $6k... I'm located just N of Orlando, but could possibly travel for serious buyers. Call/text at (386)49zero-54zero7.
- poling platform
