JVRAT said:
Man i really like your camo. I too got the Parker Sand color. How did you do the other colors? What do you mean by Bore cleaner? Our teal season starts on Sep 10th so i need to get this paint thing fnished haha.. By the way the boat looks great!
By "Bore Cleaner" I meant that I used the spray tip off of the aerosol can. Bore cleaner is used to clean the inside of a gun barrel. It just happened to have a very fine spray. I just use that fine tip on the regular camo paint cans and spray fast streaks across the surface to be painted. Maybe I'll post a video!
It has been a while since I updated my post. I ended up wiring some switches, lighting, blah blah.
I used trolling motor plugs for.... the trolling motor, my head lamps and my handheld spot light to I can use any of the three plugs in the boat for the separate items.
This is just a pic of the inside wiring courtesy of my buddy (the electrician). My wiring would be much sloppier!
Here is the switch panel, master cutoff, Cigarette lighter plug, and trolling motor plug/outlet.
Then came Gator season! And to answer Reed's question about speed. With a full load of:
5 gallon gas tank, spare gallon jug (full)
(2) Batteries
life jackets
Paddles
Trolling motor
Gator Gear
Me - 190lbs
Buddy - 235lbs (Being polite)
Full wood deck
tools
misc
and frog spit on the bottom I get 15.6mphLoaded / 19.2 mph empty
Here are a few pics I took while we were hunting:
And our Catch!
Small one was a little over 8' and the bigger one was just over 10'. Good times with good friends!
I'll see about posting a video of my "Shade Tree" Painting technique..... if you can call it that!
