Hello guys! Great forum you've got here. Got an issue with a boat I picked up this winter. Its a 2001 Landau 1680 Modified V with 60 Mercury 2 stroke engine. It has side console steering and is rated for max HP of 60. The boat planes easily and cruises nicely however when I apply full throttle the boat will push the bow down and plow into the water. The water is breaking at the front of the boat. When I try to trim the engine up to raise the bow and increase speed and RPM the bow never really raises and the prop will blow out. Also if the engine is not tilted nearly all the way down it will blow out easily in turns. The transom is a 20 in angled transom and the engine is a 20 inch shaft. The engine is mounted as low as it will go. The anti ventilation plate is just even with the bottom of the transom at neutral trim. I raised the engine a couple of holes just to eliminate that as a problem and the condition was not better or worse. The prop hub is not spun so that is not the issue. At WOT and in a plowing condition the boat is running 31 by GPS. The engine feels like it is lugging and has RPMs to spare but all the drag of the hull is holding it back. I have noticed on the bottom of the hull at the transom there is a hook right at the transom across the entire beam. With a straight edge the hook is probably 12 inches long towards the bow and the gap between the straight edge and the hull is maybe an 1/8th of an inch. It almost seams as if it came from the factory because it is very uniform across the transom. I like the boat and the layout and the motor runs great but it is frustrating not to be able to run at high speed if needed. Anybody have any ideas?
