16ft Mirrocraft V-hull build!!**Finished!!!**
Well since it is going to be a pain to get that engine low enough I think you should just turn her over to me.....I hear its real hard to make a jackplate........ :lol:
Low isn't the problem :LOL2: I'm hoping to get this thing mounted in the next few days. Right now it is riding around in my Jeep posing as a 200lb missile should I get in an accident :shock:
Jack Plate project almost complete! It was actually quite easy to make, I think I'm into this little project for around $75 and more than half of that was for stainless hardware.
Should get the Yamaha on this weekend :mrgreen: If I do get it mounted I'm pushing for a lake test Monday, cross your fingers!!!
bigwave said:
What is the plywood with clamps on it?
It will bolt to the back of the jack plate, it's not really necessary but it will space the engine back another 1.5".
Basically I built this exact jack plate:
https://www.theonlinefisherman.com/forum/6-general-boat-talk/33-homemade-jack-plate
All Mounted :mrgreen: Probably no test run tomorrow but I'm getting close!! She cleaned up like new!!
I think I still need to move it up a couple inches, right now it is set to the lowest setting....thoughts?
Looking good.
I don't have any experience with jack plates, but I would
start with the cav plate about even with the bottom
of the boat, and make adjustments from there.
I say it looks good where its at, since it is on the lowest setting it looks like all you need to do is adjust the engine out or in a little, like previous poster said try it there and adjust until your satisfied.
I'll try it out as is for now!
The good news is I finally settled on a floor coating, white quickrete epoxy with blue flakes with the non slip added. for the price you can't beat it. I plan to put the flakes down pretty heavy to offset the glare from the white.
The bad news is I have to order a shorter steering cable. The cable is dated 1985 so maybe that isn't quite a bad thing.
Yep I wouldn't worry about adjusting it anymore until you see how she runs. Great work so far by the way and I'm looking forward to hearing how you like the floor coating you've chosen
Hi,
I have the 1976 Deep V Hull like yours, its awesome that your posting the restoration!,
I have a 40 horse also but I moved my console up. Any way, I saw the pics of the decking with the noodles and was wondering how up supported it. What did you do for the middle support?
Thanks!
newporttin said:
Hi,
Thanks!
The main floor is a full 4' wide. I messed around with some scrap wood until I got the angles right then I cut 2x2 joists 4' long with the proper angle on each end. I centered each joist then measured down @ the middle to get the height for the vertical support. I used L brackets and rivets to secure the vertical studs to the ribs and then to the floor joists. I used SS self-tapping sheet metal screws down the sides to secure the joists to the ribs. Before I screwed down the floor I ran some conduit under the floor to run wires, and as you saw filled all the extra space with noodles. The finished product is rock solid.
Great build.
I'm about to start on my floor and have been looking for ideas. Ive been reading yours and bigs and f4f a lot
Did you build a frame for your flooring or just put the noodles down and attach plywood to ribs?
Just trying to figure how I want to begin the project. :shock:
flajsh said:
Great build.
I did end up building framing for the floor. I tore up the floor you see back on pg. 5 because it wasn't sturdy enough for me. In those pics I just had center studs running down the centerline of the boat and attached the sides of the plywood to the ribs. At the end of the day it just didn't give enough support so I pulled it up widened the floor a couple inches and added joists. So now there are 2x2's running side to side above every rib, and I added a lot more noodles. Sorry I don't have any pics of that part of the build.
Hey Moberg, you said you were going to try that floor epoxy for your decks. Were you referring to the product like cooldeck for pools. I have thought about that stuff too but I would be worried about it cracking. Just curious. When I built pools we used a company called Stardeck here in Tampa....that stuff was bullet proof but we always applied to a concrete surface....never tried it on a wood deck. If you use the right stains you could make that stuff look like marble, granite with the flaky stuff....alll kinds of options.
I'm using regular quickrete floor epoxy, I already bought a gallon in white, the flakes, non-slip additive, and a gallon of clear. Hopefully I'll like the final results.
Unfortunately the transmission in my Jeep just started acting up so progress will be slow for a while.
