When I was a kid, my brothers and I used to take apart every kind of motor we could get our hands on. We moved from the lawnmower to motorcycles and eventually to our cars, rebuilt engines and all. Well, I'm older now and and wiser but have lost my skills or my courage (or both). I'm gonna need a lot of help. The first two pics are of a 1964 Johnson FD-18E I inherited and have some vague notions of making run again.
The first one looks hopeful.
The next one less so...
Tonight I took out the mouse nest and am beginning to worry...
Now you guys with skills and experience may not be fazed by that but on a closer view it seems pretty bad to me. Unless I'm mistaken, this was once a carburetor. It now looks more like some ancient Roman thing dragged up from the sea floor. I'm no expert, but that's pretty ugly.
In this one you can see down the throat a little better.
This wire or more correctly rubber insulation was stuffed inside but not connected to anything and, there was no wire inside. I don'tknow if it belongs or was a part of the mouse nest.
Two bits of good news: the motor turns over so it's not seized up. The other is that both plugs were oily which might mean the cylinder walls aren't too rusty or nasty.
So, the question is, where to start? Do I start by taking the carb off and try to clean it? Do I dismantle the whole thing and see what's in there. Do I do the minimum to see if it will run at all and if so what is the minimum? I'm not so much afraid to try as I am afraid of making a mess of it so I'll take any and all help and suggestions and remember I'm not too proud to put it back in the garage and forget about it forever if that's the best thing to do. My manhood's not at stake here so it's not one of those projects. Thanks in advance.
