arthurdent
- Joined
- Jul 26, 2024
- Messages
- 6
- Reaction score
- 2
- LOCATION
- Adams wisconsin
I bought a 14-foot Aluminum StarCraft with an F-13 Johnson 18-hp 2-cycle motor. The seller says it ran this spring. I changed the lower-end grease and no apparent leaks. The grease was clean and the right color. I have not been able to get it to fire on new gas.
Spark parks look dry so it could be carburetor issues. The gas tank pumps up pressure fine.
The motor does not fire on a touch of sprayed ether in one cylinder. The spark seemed weak when I pulled and grounded the plug. The points, condenser, and magneto have not been checked yet.
I just checked the compression on both cylinders. Cold and dry cylinders. 71 psi on each cylinder.
Low but runnable?
I want to get your opinions before I invest money and time in new plugs, points, and condensers and a carb clean/rebuild. Is the motor worth it?
The current spark plugs are Champion J8C. I believe the OEM calls for cooler plugs. J4C. Should I go with a 4, 6, or 8 heat range? NGK plug instead?
I am not panicking. The boat came with a Mini Kota 35 lb Power Drive and I have a 52 lb Mini Kota 12 volt also. It would be nice to have the 18 hp to save some travel time on the Castle Rock Lake in Wisconsin. I am hoping to land some nice Channel Cats for the smoker.
Thanks for reading
Low but runnable?
Thanks for reading
