I put a block of wood under the outer gunwale to give the troller a place to mount. I think it works better on the bow. It was easier to see where I was going, rather than where I had been so to speak. With it on the transom, I did not see weeds I was riding over. Battery was up front last in a battery box that was bolted to the forward bench on the bow side. I only used stainless hardware everywhere.JODGW1776 said:Bill,
Looks great! As a fellow New Englander, you gotta be loving the weather thus far (minus this week!). Just a couple questions:
1. How is that trolling motor mounted? Does iit work better bow or transom mounted?
2. The battery is stored up front: what are you using, if anything, to keep it in place or secure?
3. Those seats came out great. I have three aluminum bench seats as well but would like to put plywood over them. What type of hardware did you use/suggest?
Thanks.
