I had a '67 14ft Seafarer for years, it came with the original 1967 Evinrude 18hp on it.
The motor weighed 86 lbs on a shipping scale plus the 42 lb 6 gallon tank it needed. The spec plate on mine said only 20hp or 850 lbs max hp and weight. The motor, full tank of gas, a 34 lb group 24 deep cycle to run a fish finder and lights, and myself at around 265 lbs or so back then plus a few rods and reels and a tackle box at about 30 lbs or so, then add another 250 for a buddy and another 30lbs of tackle, since that 18hp was real thirsty it meant carrying a second tank of fuel, so another 42lbs when carrying two guys. It put the total load at 779 lbs and if you count a bucket or minnows, a cooler for lunch and an 8lb anchor we were probably right at the 850 lbs if not over it.
Fast forward 30 years and my retired self is closer to 325 lbs, the 18hp rope start gave way to a 130lb Yamaha four stroke a bigger tackle box and a fishing buddy that's close to my weight I suppose plus a small anchor winch and an 8 lb danforth anchor, a bow mount trolling motor, and a pair of group 27 batteries to run the trolling motor and fish finder.
I upgrade the hull in 1999 to a newer 14DLX with a 955 lbs and 30hp max rating.
They upped the hp rating when the SF went to a 67" beam width.
When I added the 20hp Yamaha the motor weight became 132lb but I no longer needed to carry two 6 gallon fuel tanks. so the added motor weight was a wash overall. At that time the 25hp was a heavier motor and not an option weight wise even on the newer hull. As it sits now a typical day out on the river would be,
20hp 4s motor - 132
6gal gas - 42
two group 27 deep cycle batteries 110 lbs
trolling motor - 42 lbs
tackle 41 lbs
me - 325
buddy -240
buddies tackle 10 lbs
cooler - 10 lbs
anchor 10 lbs
The boat is still overweight but there's not much I can do about it other than go back to an older, smaller two stroke motor
The new hull is the Alaskan style hull, similar to what they currently marketed as the Alaskan 15.
The newer hull was a major improvement overall in the amount of power it took to push the boat along and in stability. The sleeker bow rake and wider beam made it more like a 16ft boat than a 'big' 14,
