Greenhead
First off let me say hello to everyone from South Dakota. Awesome to see the amount of knowledge here. I have been reading so much my head is kind of spinning. I am really pretty much new to boats, at least aluminum boats. I just picked up a 1973 Lowe 1648 Jon, I am pretty sure it is a "Big Jon" 16. At least according to a 1975 flyer I found on the Lowe website. I do know the floor is 48", sides are 20" and the transom is 63"x15.5" I couldn't find anything older than the 1975 flyer. I bought it with a Shorelander trailer (13" wheels) and it also had a quickset Avery blind on it, no motor.
My plan for the boat is just for duck hunting, and then out a few times in the spring/summer to keep things in check. Most all the hunting I do is on sloughs or small lakes/ponds. I am here really to get thoughts/concerns and look for some feedback on my ideas. I do know the transom is shot and needs rebuilt and Id like to put flooring down for starters.
My first question - Should I just keep the wood transom the stock size? Meaning should I just replace it with the same size wood cutout, or should I fill the entire height of the transom with wood, too the floor? According to 1975 flyer motor rating is 30hp. Would I be in trouble putting a 35hp motor on it. I am more than likely going with a surface drive. Most all I see available are 23hp or 35hp, unless I build my own with a sd kit and motor I supply, then I could get something close to 30hp. Or just stick with a 23hp build the transom out to stock size and call it good? Guessing most will say keep it stock and save the material and weight for something else....
Next question - On the outside of the transom there are rivets that stick out about half an inch, basically where the motor would mount. Would this be fore like a trim plate or something? Can I remove them so it is flush for when I do get a motor? In the pic you can see an outline, the rivets are within the solid area.
Last question for now ha - I plan to put down some wood flooring. Do I need to fasten it down? If so could I just use some angle iron and bolt it to the benches, thoughts? I don't care how dirty this gets. I am not going for plush comfy hunting but I don't like the idea of walking across the bare floor and ribs
Thanks in advance look forward to your replies!
