Pappy said:That is water.
Pappy said:Your terminology is not quite right but you are on the right track.
It is the thrust washer that is missing and that is never a good thing. That washer runs on a taper on the propshaft and absorbs the total thrust load of the propeller.
The thrust washer also locates the propeller and keeps it from running too deep in the exhaust area of the gearcase so, chances are your engine now has a labyrinth seal that is destroyed. Not great but not the end of the world. You may experience more than a normal amount of cavitation due to this.
Also not running the thrust washer usually makes a sharp edge out of the rear of the gearcase where the prop slides in.
Prop is probably damaged as well from not running the washer.
BTW What you are calling the thrust washer is commonly called a spline washer.
On your engine there is no need to over-tighten a prop nut.
