k2sno070:
First, thanks for the compliements! Lots of questions, I'll go through them in order:
>> What pedestal bases and seat systems to use. What did you use on your boat and do you like the performance so far?
I used a "pin base" type of system. This system was in use when I started my first mods on my first boat when I was in my 20's (a 59 14' Starcraft that I still own). It was all I knew so I chose it for this project. I went "on the cheap" because the bases were pretty damn spendy, as well as the posts. The expensive ones have brass inserts for the pins, and thus, do not flex or shift very much. The ones I have use plastic fittings, and will eventually wear out, and definitely flex far more than the brass inserts. This is not a big deal on the shorter bases (like on the front deck for my fishing buddy) but when you get a longer base (like mine in the back, I am 6'3" and over 2 bills) the torque I can place on it is definitely not supportable. I bought a chair-like mount for a boat seat, thinking I would use it for the middle seat that could be removed easily and left on the dock for people to sit on (shown in the pictures). I ended up using that in the back instead of the cool angled pin base seat that I was planning on using to allow me to swivel from one side of the boat to another, and not have to offset the pin base for when I was underway and need to be driving. The torque was FAR too much for the pin base. I would eventually rip out the flooring, even though it was anchored to the underside of the wood with aluminum strips, and bolted to the aluminum I-frame center beam.
Instead, I would go for the taper-lock style system (really wide pin base, basically). The benefit to this is that you can buy a ton of accessories that fit that system like a table top like you find in many pontoons, or a grill stand, whatever... nothing is made to fit a pin base for accessories like this.
>> How did you brace the sides of your boat? Did you use some brackets or did you just install the storage.
First was the flooring. I ran structural supports from the I-beam to the tips of the stringers and riveted them down. The flooring is over that, and screwed to the supports in the middle, and to the tips of the stringers at the edges.
Next, the framing for the storage is fastened to the flooring and the sides of the boat. I used aluminum angle and cut off 2" sections and riveted them to the sites for support. Those were tied to aluminum that ran the length of the boat that were anchored on structure like the split seats or the casting deck. To support the runs, I ran vertical posts that were fastened to the flooring. I then ran cross-beams connecting the runs to give everything rigidity. I can easily stand and jump on everything with no worries of anything breaking. I did extensive research on other folks doing the same thing, so the takeaways are: use non-big-box aluminum (6061 for strength). All I did was google stuff like "6061 aluminum boat deck" and watched and learned and refined my searches for more specific details. I reused the seat brackets on the front for support, but I also framed in what I believe is a pretty damn sturdy foundation for the casting deck (you can see it in the pics). No flex anywhere on that deck.
>> How did you fill in the voids of the previous rivet holes?
I used rivets! I coated them with 5200 and then popped them in place. For under the waterline holes, I used closed end blind rivets. It worked great, and looks natural, as there were rivets there in the first place. For the huge holes in the top of the aluminum in the front of the boat where I removed the original carpeted trolling motor mount (at least 3/8" holes) I used 1/4" rivets with over-sized heads, it worked awesome, and those holes look like they are factory rivet bumps. On the sides where I replaced all the removed benches and added brackets, you don't notice them at all with the paint job. They blend in just like it was a new boat.
