dyeguy1212
Wow must be nice.. I literally too a spade shovel to mine... but all I did was cut out a rectangle on the top and leave the rest for storage
kbkid said:Ah, no big deal.
I kind of like the amount of room that opens up once the benches are taken out.
Also, I was thinking today that maybe a rod locker won't be quite possible. I'm beginning to think I'm trying to squeeze too many components into the boat I have now. I may just make a narrow "countertop" between where the rear and middle bench were and extend it up to where the front deck will be.
I don't want to make the front deck too tall, so I may just run it directly off the very front bench. Tomorrow afternoon my description should be better to under, as I should have most of the framing cut.
Check back tomorrow for additional pictures.
The reason they didn't use treated wood in that boat is because the treated plywood of that time had copper chromium arsenate in it, which is very corrosive to aluminum-don't ask me how I know this. Nowadays they do make cca free treated marine plywood just for aluminum boats. So its safe to use on your boat. I have a 12' Gamefisher that I bought when I was 13 years old-I'm now 42-and I didn't have to replace the transom until about 5 years ago. I used stainless steel button head machine screws with 3M 5200 and they held up just fine. In fact, every time I find loose rivets in the bottom of the boat I just drill out the rivet and replace it with a machine screw and 5200 and they all hold up just great. Just make sure you use the nylon lock nuts to hold them in place.kbkid said:The transom was not treated with anything. I was hoping since it was exterior grade ply, it would hold up to a little bit of weathering.
The boat is garage kept, so if the transom holds up for a couple seasons, I would be more than happy.
Is it true I can find the 5200 and 4200 at most Wal-Marts? If so, I may pick some up. I'm hoping the silicone will be fine for now, but if I ever go back and use rivets, I'll be sure to use the 3M product.
