I pulled my 14' Smokercraft with 9.9 Merc 2-stroke out of the barn to run the engine for the first time this spring. I acquired this boat last fall from my father who took excellent care of the entire rig. I wasn't in a position to spend a lot of time with the boat/engine last fall (new baby), so I did a hasty winterization and put it away. I'm wondering if I burned myself...
On my first go with the boat in the yard and engine in a 50 gal. garbage can of water, I noticed that the fuel line and priming bulb were hard as a rock (age). I tried squeezing and seeing if the engine would start, but got nothing. I figured my issue was fuel delivery, so I ordered and installed a new Evinrude brand fuel line with bulb.
Today, I pumped up the bulb until it was firm, choked the motor, and proceeded to wear blisters on my hand from pulling so much. After a lot of messing around, I finally pulled with one hand while holding the throttle plate open with the other hand, and the motor roared to life. I ran it for a long time to pull new, ethanol-free fuel and some cleaner into the carb.
This morning, I went back out and the same deal - impossible to start, and didn't have time to remove the cowling.
Once the engine is running and warm, it will start with barely half a pull and idles well. But when the engine is fully cold, all it will do is sputter and cough unless I do the throttle plate trick. I have not sprayed it with carb cleaner yet but wanted to get any additional tips/tricks that may help get this running right WITHOUT taking off the carb. If I have to pull the carb, I may consider the 15HP carb to boost output.
Thanks!
Thanks!
