zekepa
Just picked this boat up Monday. Its a 1995 Mirro Craft MV 860, specs I found online say it is around 450 lbs, 18ft long, 60in wide at bottom and 84 in beam width.
Will be looking to turn it into an electric only lake boat. Currently fishing out of a 1994 Bass Tracker Super Pro V16. I'm hoping this boat will be a little faster with a trolling motor since it is lighter and different hull type.
I'm sure I'm going to need advice from the members once I get started on it. Planning on stripping the current interior out, as a winter project.
At a minimum I want a rod locker down one side that will hold 9ft rods without taking them apart. Consoles will be coming out. They are actually the original storage compartments that the previous owner turned upside down and fabricated bases for to make them consoles. One was a livewell the other storage. He cut holes in both so I've got some patching to do to make it back into a livewell.
