Let me start off saying I love the site and have looked through numerous posts and pictures on what everyone has done and i'm impressed. So this is my first alluminum boat overhaul and I have tons of questions that I hope some of you experianced guys can help me with. I basically inherited a project boat from my brother in law whom served in the army in iraq but sadly did not make it back to finish his project. Before he left, he gutted his boat and was never able to start rebuilding it. Instead of selling it off, my dad and I are going to fix it up like he had planned.
So here it goes... I have an 18 1/2 x 7 Sea Ark alluminum boat that needs a lot of work. It has a 2002 Mercury 75 hp four stroke on the back and a trolling motor in the front. It has trim tabs, jack plate, bildge pump and a poling platform. Everything has been gutted as hopefully you can see in the pictures I'm going to try and attach. The metal cross beams have cracks and need to be welded back together. Here is the issue: this used to be a side console boat at the back of the boat. The weight of the four stroke engine, gas, batteries, driver and passenger made the rear of the boat sit very very low in the water. So my brother in law had already purchased the center console and a seat/metal storage bin that was mounted in front of the console. Our plan is to convert this from a side console to a center console and would like to move the center console up a bit so we distribute the weight more evenly from front to back as well as side to side. So here are a few(a lot) of questions:
1. Does the center console need to be welded in place and then install the wood decking? or do you install the console with ss screws/bolds to metal supports? Does the Seat mounting bracket screw to the decking or is that welded to the support beams and decking built around it?
2. Running wiring to center console; there is cut out on the side of the console for wires, so do the wires run under the decking straight to the back of the boat or to the wires run along the side of the boat from the motor and come into the console from the side? (hope that makes sense)
If they run straight from the motor, under the seat, then to the console, there doesn't appear to be enough space once decking is layed for the wires to fit. with that being said, Do I need to custom make a shield to protect the wires coming from the back of the boat to the enter console or is there a trick or something I'm not thinking about?
4. When installing the decking/marine plywood, the area in front of the console as a slight V curve to it so do you make the deck flat by installing a piece of wood or metal under the center or other options?
5. Is there a good website that has wiring diagrams for boats/boat motors, trolling motors, etc.
6. I took two different pictures with the console in two different locations; one is having the center console installed so the drivers seat is just in front of the rear compartment. The next one is with the center console moved up so there is enough space between the driver seat and the rear compartment to probably fit a cooler and to walk behind. What is your opinion pros/cons to the different locations? Is there any safety issues that I need to think of by moving the console up too far?
7. Are there any suggestions/reccommendations/heads up/etc.. that I should be thinking about before really getting started?
As you can see, I'm a novice at this but I'm as handy as they come. I'm excited to take on the project but always like to have a plan in place before getting started and hopefully avoid others mistakes and lessons learned the hard way by asking ya'll. Any help would be greatly appreciated.
Thanks
Mike
Thanks
Mike
