[url=https://www.tinboats.net/forum/viewtopic.php?p=344661#p344661 said:
ccm » Yesterday, 01:49[/url]"]I used 3/8 inch thick rubber horse stall mat in the bottom of my shallow v boat. I don't recommend it for your application. It is heavy weighs similar to a sheet of plywood in equal thickness. Not exactly cheap either when compared to plywood. 4X8 piece at $9.50 per linear foot = $76. It would give the floor a spongy feel over the flotation in the floor in my opinion. If aluminum sheeting is out of the question, my suggestion is to use properly sealed plywood with 1/4 inch rubber matting on top of it. If you are going to keep the boat for many years to come get the aluminum sheeting. My uncle & cousin had an 18ft flat bottom decked out for bow fishing (lights, platform etc...) They used aluminum diamond plate for the floor and removable platform, it was a lot nicer and more durable compared to the old plywood they replaced. ( they got the plate for free only reason it was done that way )
Pro's & cons of rubber matting
Pro's
#1 non slip & excellent traction when wet or covered with fish slime and blood
#2 Sound deadening, makes the boat super quiet so you wont spook fish
#3 comfortable under foot
Cons
#1 Gets super hot during the summer making it a little uncomfortable to fish ( radiating heat )
#2 hard to clean without a good scrub brush and liberal application of dish soap
#3 heavy when compared to other materials.
