Well time to wake this thread up! I’ve taken a big break on this thing and now that the weather is warming up again I’ve gotten the itch to get this thing in the water. Quite a bit has gotten done since my last updates.
I finally got some man time in the garage last night and got a bunch of work done on it. Got the majority of the wiring, decks, hatches and lights mocked up. I can’t believe how much wire Ive stuffed into this little boat lol I still have to take everything out of the console and paint all of the wood on the inside. I’ve grown to be pretty OCD and wiring and especially in boats so here it is roughed in...
I also wanted to have a light in the console in case of an emergency but I didn’t want it to be one all of the time with the rest of the hatch lights. My solution was to run it’s one circuit with its own switch inside of the console. Keep in mind all of this wiring is just mocked up. I still have to pull it back out to paint the inside of the console.
It’s the little details to matter to me haha
So I found these lights at Walmart that are water resistant and they are made to go in the bed of a pickup. This whole time Ive been planning on doing L.E.D strip lights but these things were way to bright and convenient to pass up. Come to find out they fit absolutely perfect in the HDPE “tuffy” boxes I’m using as inserts in the back. These boxes are cheap and support over 200lbs on their own. That being said they are now removable if I ever need to access any wire or rigging.
I also took some time last night to sort through the factory harness and get rid of all of the factory non sense that has been replaced or isn’t needed. That’s a lot of useless wire. The second pic is what’s left of the harness and it’s mainly just for the engine and throttle assembly
I also made up some new power wire for the motor out of some 6/0. Even tho I wouldn’t have used it, the old wire wouldn’t reach anymore because I’ve moved the batteries from the back up to the console.
One more thing I got done last night is got the gas tank finally mounted in its new home in the front deck. Major pain in the butt getting everything lined up and fit correctly. The filler neck is now flushed into the front deck. Even tho there really isn’t anything to see, here is the filler neck in all of its glory! (Sorry the boat is a absolute mess)
Next on the agenda is getting the boxes built for the front deck, getting the lights mounted up there and start coating the decks with spar and non skid.
