PSG-1
I'm wondering if anyone can help me figure this out.
Bought the engine new in 2009 (it had sat at the boat dealer's lot for a couple of years)
Once it was running, it was fine, but starting it is another issue. It's always been a PITA to start, but recently, it was getting worse.
So, I changed the spark plugs, it still had the factory plugs in it. After I changed the plugs, it cranked right up, but when I go to hit the throttle, it acts like it's running on 2 cylinders, or it's starving for fuel, I can't figure it out. Takes forever to get up on plane, and it's not reaching max RPM.
I'm wondering if I somehow pulled a spark plug wire loose from its connection in the boot when I changed the plugs. That's the only thing I can figure, because, like I said, it was running fine before I changed the plugs, other than the issue with hard starting.
Any ideas?
Any ideas?
