2009 mercury 20hp 4 stroke not running right
lovedr79
Harrisonburg, Va.
today while out on the river motor ran fine, was getting 20mph loaded with two people lots of gear. fished for awhile started back up river suddenly lost power. all i could get out of it was 6.5 mph. sounded like it was over loaded. cutt throttle back nothing, choked out. fuel line bulb wouldnt get tight....... took the pickup tube out of the tank, primer working properly just wont get tight. no fuel leaking out anywhere. i came home pulled plugs out they were slightly yellow. fuel filter clean, bulb tight after a squeeze or two. how do you check the fuel pump? i pulled it off but wasnt sure if it was like an old V8 fuel pump. i can blow throw it the way fuel flows, but cant blow through backwards. makes a whistling sound when you blow through it. you can also free rev with the throttle only but as soon as u put a load on it, it becomes very sluggish. not many hours on this motor either.
That's on the list along with checking for air leaks at quick connects. Don't think it is as its not sputtering. How do u check the fuel pump? I have pulled it off but can't dissasemble it.
Pull the fuel line off of the carburetor and crank the engine. Should squirt fuel out. If not, either something is plugged up, there is an air leak on the suction side, or the pump is not functioning. I like to use a glass jar for fuel samples. It'll be obvious if the fuel pump is working. It'll also be obvious if there's moisture in the fuel.
Carb. I drained the fuel last night. No water. I did use the bulb to start the siphon, but it stopped a couple times, squeezed it and it was pushing air back into the tank, then it would also not do anything, so I believe the valve inside the bulb is the culprit. It was a new bulb the day it started acting up. I rapped it on the floor and it started functioning again...... So I will refueling with new fuel and try a new bulb. I really hope that is all it is. I was also going to hook a psi gauge on the fuel line to see how much pressure the pump is putting out. But not sure what it should he putting out. I was thinking around 6-10 psi?
Make sure your bulb is not on backwards
truly irritated now. new bulb, filter, fuel line connector, ran great for about 15 minutes, then lost power again! i believe it is the fuel pump. i popped the line off yesterday and cranked it, i got fuel pulsing out. didnt seem to be under much pressure. i also realized i have warranty left, anyone ever do a warranty claim with mercury?
well it dawned on me I have warranty left, took it to a mercury dealer, they went through it. Ran in a tank, ran it on the water NOTHING........ So I went to their shop put the boat in ran it wide open for half an hour wide open. They claim they didn't find anything, mysteriously my motor runs smoother, starts easier and I am now getting 26 mph! Now someone explain that! The most I have ever gotten with just me in the boat was 22mph. And I got slammed with a $200 bill since they didn't find anthing........
Does the 20 HP Mercury have overheat limit? If it does...it "could" be in the pump (low volume).
I know on the smaller Yamaha's (all I've dealt with in any detail-haven't messed with Merc, Mariner, OMC much), they have overheat limit built in. If engine temp exceeds I believe 196 degrees, the CDI limits engine speed to about 2000 RPM. Just barely above an idle. Typically the complaint I get is "runs great for 10-15 minutes, then falls on it's face...shut it off, let it cool, does it all over again".
Not saying yours is "that" problem...but could be. But if it's running good now, I reckon it's good to just leave it as it is until it breaks.
