2014 Alumacraft mv16:
Thanks buddy.
Just started the first lil bit of construction yesterday...
Mounted the bilge pump...
I also mounted a three light l.e.d. to come on when I switch the pump on...
I also picked up a 13x24 hatch from the local marine warehouse here in Tampa, TAMahoneys, over on Adamo&50th st.
Took the boat over to my Dads place and he helped me cutout some holes with his jigsaw....
This is the rear bench/seat:
Thx again Dad!
Im gonna have to reinforce the bench to accommodate my fat butt, and a battery tray or something flat for a battery tray....
The speaker cutouts, and switch panel:
Careful with that bow light. Uf you are putting a trolling motor mount you may want to wait untill its complete yo figure out placement of that light.
Good idea.
Thanks buddy.
Did you have yours done at a alum fab shop?
Did they match the paint too?
Got two group 29 deep cycles in:
Ive got the battery selector switch aswell....
=D>
This is going to be a build to follow. Can't wait to see what you do with it.
Started to get down with a little of the pre-wire:
#6 tin coated fancy wire for the trolling motor
Speakers get #16ga wire
All the power and ground wires get sent back to the electrical panel via 3/4" pvc
Nothin better than crystal clear reception!
Yes, thats a marine grade am/fm antenna! :shock:
I need some stainless hardware...
This is how I am routing wires through the different compartments...
We call 'em chase nipples:
Im going to use these polycarbonite boards as backing for the battery selector switch, and battery charger...
The negative terminal bus bar will look good on it aswell...
Heres the before and after on the lightpole socket:
AM/FM antenna installed and tucked away...
...and two more bluewater leds goin in where the radio will be:
Ive been using these heat shrink buttsplice connectors...
These things are great: 8)
Got the two bank battery charger installed: =D>
