Thanksshallowminedid said:shay fb knows the dude stalk his friends list for lance dunham or ldguideservice.com last i heard he loved it on a 22 or 24 ft sea ark with float pods think he said it did like 47mph or something like that
I appreciate it. Do you have pictures of a 250 SJ in a low pro?Kevin Turner said:At the risk of sounding like a know it all, if you're intended use is bass fishing the SusQ, I wouldn't recommend the 250 SJ. The 250 has a bigger foot print, heavier, and less reliable than the 200.
Roost said:I appreciate it. Do you have pictures of a 250 Sport J in a low pro?Kevin Turner said:At the risk of sounding like a know it all, if you're intended use is bass fishing the SusQ, I wouldn't recommend the 250 SJ. The 250 has a bigger foot print, heavier, and less reliable than the 200.
Thanks KevinKevin Turner said:I only installed one 250 SJ. I'll see if I can dig up some pics...
Thanks, ill look into that info!Lil' Blue Rude said:If you wanna hot rod the motor go take a look at screamandfly.com Lots of big merc gurus over there. Personally I'd go with Chris Carson reeds or TDRs reeds. Boyseens don't last very long and the perfomance gains start to fade. They don't seal as well after a couple hours running and Carson and TDRs are cheaper. They make custom reeds for ported reed cages.(easy safe gains)
Roost-Roost said:As im sure you know the EFI motors aren't as reliable or fuel efficient as the opti's. That 3.0L is very intriguing to me.. If I could score a used 250 cheap, refresh along with slapping in some new boyesen carbon fiber reeds, WSM pistons and do a little port work without sacrificing reliability the power to weight ratio would be greater then the new 200 opti and id still save a few bucks...
Generalities here…Roost said:No worries Kevin, Don't hold back. I appreciate your thoughts. I'm curious what your concerns are and I'm really anxious to see the pics of the motor in one of your boats.
