28 lb thrust trolling motor
If your boat has decks and floors, then I would not go with the 28lb thrust. I had a 33lb thrust on my 14' jon with large front and rear decks, floors throughout excluding the bilge area, 2 batts, 3gal tank, and 25hp OB. TM pulled fine on calm and light winded days, but it struggled in moderate winds. With mod winds, I have to run on 4 power setting into the wind. Boat would barely craw forward on 3 setting, and would lose ground on 2 setting. I've recently upgraded to a 40lb thrust TM, but have yet to test it.
I have a transom mount hand steer 36# thrust and seeing what a light wind does to these boats, I would not recommend anything smaller. 35-45 should be the proper range without going overboard on cost.
I'd go higher, 28 lbs aint nutten, I'd be willen to bet if a stiff wind kicked up youd be SOL, had it happen to me with a Tracker bantom 3x, abs plastic, 8 ft, barely made it back to the ramp, so I put the 28 up front and bought a 3 hp electric trolling motor for the back.
There are a couple listed on craiglists, one a 52 lb foot controlled minn kota for 225 that needs a prop and a foot controlled motorguide 42 lb for 175. Any suggestions?
Unless your boat is decked you are not going to have use for a foot controlled model. Although, teh 42 lb for $175 is a decent deal. You really want a transom mounted model. I use TWO 34 lb TM on my 16' MirroCraft and it was still a long slow ride on any decent size lake - at 3-4 miles and hour it would take over an hour to get from one end of the lake to the other
Keep looking - you can usually get good deals on the transom mounted TM
I have a low deck in the middle right and plan on putting a similar one in the front. I also have a 7.5 hp ob for the back, thats y i was thinking that a foot controlled bow mounted would be a nice edition if i could find a could deal.
