moark
Hello everyone! Been reading this board for quite some time and learned a ton but I now have an issue I hope some one can help me with.
I have 1990 Basstracker Pro 16 with 1996 50/35 horse 4 stroke Merc jet. I took it out it the other day and it ran 5200 rpms 26 mph for about 45 minutes then started to miss and lug down to 4000 rpms and would not get higher. I fixed several light gas leaks between tank and fuel pump and changed the fuel pump and now get 4600 rpms. The manual says the motor should run between 5500 and 6000rpms. The fuel tank is up front which is about a 12' run to engine. Are jets supposed to run rated rpms or lower? Any help would be appreciated and sorry for the long winded thread.
