Hanr3
Hola all,
I have been trying to get this motor back into great mechanical shape.
Things I've done.
New coils, condensers, points (.20), wires, and plugs (.30). Basically a new ignition system.
Rebuild carb with a new plastic float (the cork one has seen better days and was delaminiating), although I have some questions.
Is there an adjustment to the float?
The center brass thing that sticks up appears to be broken, purpose/problem?
Replaced the water pump, well was going to replace it, however the one in there looks almost brand new.
Pulled lower unit and cleaned out the gear assemble, new lube.
Onto my hick-up.
I adjusted the high and low speed needles. High is almost closed now, low is 1/8" off closed. Engine runs but has a hick-up, the faster I run her the less of a hick-up there is, more like a burb. IF I go too slow, the hick-up will kill the engine.
What could cause this, and more importantly how do I fix it?
I need to go fishing this weekend in my plaid and win the first tournament. :mrgreen:
Things I've done.
Onto my hick-up.
