Today I got inside and scrubbed most of the oily gunk out of the inside. I hadn't bothered to take the foam out from under the splash-well so I finally got around to that too. I was probably in denial about that last bit because, as I should have known, I finally got to see the bottom inside of the transom and yes, I have to take it out and replace it. Dang it anyway. There's a built-in design flaw that could only have ended in the transom having rotted away (red ellipse). You can see in the photo below that the stringers running the length of the inside attach to the transom with screws. There are three on either side of the center following the curve of the bottom. Water drained to the back of the boat between the stringers but there was no accommodation made to drain the water down to the center and out the drain hole so water was trapped on the upper side of the stringer (green arrow). I'm going to have to drill holes (blue arrow).
To do a proper job of it I should take out the splash well rather than try to slip the wood past it but that's a mean mess of rivets to grind off and remove, plus three drain holes. The plywood is a single thickness or I'd see if I could cut off the bottom half of the inside sheet if it were two 3/4" pieces glued together. You can see how many rivets I'll need to take out in the two photo's that follow. The last photo shows the cast corner pieces and the bent cap on the top edge held on with headless nails. This a drag and I'm not looking forward to having to do it.
Can anyone explain the rivets to me? I'm not sure how to replace them. I'm familiar with pop rivets but these are factory jobs and I don't know if it's possible to replace with the same kind. What I really wish is that I could dry the wood and impregnate it with resin or something that would prevent any further rotting and also consolidate the wood that's there. I'm going to look into any alternative I can to avoid doing this. Any suggestions would be appreciated.
