63 Johnson 40 hp outboard
vtflatlander
Danville Vermont
LOCATION
Danville Vermont
I have a 1963 Johnson 40 hp outboard motor. It is set up for controls. My question is is there any tiller set up from another Johnson or Evinrude motor that would fit this motor. I would like to change it over to a tiller for my Aluminum boat. Thank you
Just about any of the 25-25hp engine family will fit that engine. The trick is to get the shaft and gear on the engine side of the tiller! Your current position indicator knob and shaft will have to be changed out to make it work. Easy job and tillers are plentiful but just make sure to get all the parts off a donor engine.
