Johnson outboard wire harness help
You can easily buy what you need from a number of sources. Used, OEM, Aftermarket, whatever. Prices vary.
New OEM harnesses of all types:
https://www.boats.net/search?q=evinrude+remote+harness&ui=typeahead
New aftermarket harnesses:
https://www.amazon.com/s?k=evinrude...nrude+remote+harness,aps,177&ref=nb_sb_noss_2
One that should fit a smaller aluminum boat from the selections above
https://www.amazon.com/dp/B07FCGRJ1Z/
Used harnesses on Ebay- there are a bunch of them you can choose from. Here is one:
https://www.ebay.com/itm/295100986078
When I need a harness, I usually go on Ebay and see if I can find one for $50 or so. Lately, they are mostly around $100 +/-.
With small engines, when they overheat, it's sometimes easiest to just replace the harness when available. The overheat sensor you can replace, use liquid electrical tape, or even regular tape, if you want. It's up to you.
Don't want to offend, as I don't know your mechanical level, but hopefully this is helpful
https://www.amazon.com/s?k=evinrude+remote+harness&crid=2N3N80V7114IS&sprefix=evinrude+remote+harness,aps,177&ref=nb_sb_noss_2
That's very helpful, thank you very much.
