riverbronzeback
- Joined
- Aug 1, 2008
- Messages
- 53
- Reaction score
- 0
Ok guys, my buddy has a mid 70's johnson 50hp. First time we took it out it ran great. We got about 30mph(mid 70's 16ft basstracker, decked out.) Sounds like it runs pretty well, he just did both carbs in the fall. Next time we went out all he could get is 7mph although it still sounds like it is running good. He thinks it is something to do with the current as first time we were on a lake and when it started running bad we were going up river in a pretty good current. I told him to check spark cause it seems to me it might be running on one cylinder. I dont think it has to do with the river current. If he had bad compression it would run bad all the time right? It just seems weird if it was spark that it would do intermittently. Unless he has a coil/condenser wire rubbing on something sometimes. Primer ball was still firm and pumping it had no effect. I think he has a cylinder not firing sometimes. What do you think? When running well should he get more than 30mph?
