80's Sears 15 speed Gamefisher electric motor
bobby_r67
Ashland Ohio
I have a 1980's Sears Gamefisher electric fishing motor 12 volt. I believe the forward and revers switch is bad and of course it is no longer available. Can you suggest a replacement. I guess you would call it a 3 position switch. Off, forward and reverse. There is also a wire running to the 15 speed rheostat off of this switch. Thanks
ImageUploadedByTapatalk1408570530.043929.jpgImageUploadedByTapatalk1408570543.810515.jpgImageUploadedByTapatalk1408570553.676876.jpgImageUploadedByTapatalk1408570563.327606.jpg
Bob Rusinko
“The true soldier fights not because he hates what is in front of him, but because he loves what is behind and beside him."
That looks like a switch that you should be able to get at an auto supply store.
Found a switch but it wasn't easy. I also had to run 2 jumper wires because of the rheostat. If any one has this problem contact me I'll help you out.
