[url=https://www.tinboats.net/forum/viewtopic.php?p=352469#p352469 said:Turk » Today, 5:32 am[/url]"]...
Also when checking out the lower unit I noticed a bearing bouncing around free in the housing. I figured out where it went but I screwed up and am not sure which way the shift gear goes. It has a groove on one end does it go toward the forward or the reverse gear.
[url=https://www.tinboats.net/forum/viewtopic.php?p=352513#p352513 said:Turk » Yesterday, 12:49 pm[/url]"]Thanks It looks like its in good shape I appreciate the help. Anybody got any ideas on those O-rings?
If they are actual holes and not leaky rivets you may have to put aluminum patches over the holes.[url=https://www.tinboats.net/forum/viewtopic.php?p=346804#p346804 said:Turk » Sun Mar 30, 2014 10:16 am[/url]"]I filled it up with water and I have a bunch of pinhole leaks along the ribs of the bottom....instead if trying to weld every tiny hole up I was wondering if I could just coat the inside or outside with something to plug them up....any suggestions?
