Truckmechanic
I have a 87 Evinrude 9.9 tiller model that is giving me problems, I know it is small but maybe you can help me out. I will get the model and serial info as soon as I can and get it posted.
-When start up it runs good at idle. I go to throttle up and get about 1/2 throttle and and it begins to die. If I can catch it before it dies and open up the choke it will throttle up the rest of the way to WOT but still run kind of sluggish. I had done some research and all I could come up with was a jet in the carburetor was clogged so I disassembled and cleaned, put everything back together and runs exactly the same. Also if this helps it runs the same on muffs as it does in the water.
