Adding a drain plug.
Amkev14
LOCATION
Reno, Nv
Hey everyone, I have a 12 foot Montgomery Ward Sea King that apparently wasn't made with a drain plug and I would like to add one. The rear wall of this boat is thin aluminum and I'm looking for help on the best option without the need for welding if I can avoid it. Thanks guys.
I kinda figured that was the route I was going to have to go. I was just curious if there where any other options. Would you happen to know what type of sealant would work best and would last?
Haven't looked for one of these in years but...way back when, there was a two piece add-on drain for boats, one with a male thread and the other half a female thread. A hole was drilled ( guessing about an inch) then these two haves were screwed together sandwich ing the hull in between. Used a couple of these in my youth, early ones were a bronze type but later ones were plastic material. Back then found in hardware stores....today ??
Airshot..Bulkhead fitting?
Not sure what they called it, but just a male threaded half then a female threaded piece that sandwiched the hull in the middle. Left a 3/4-7/8" thru hole that a plug would fit into. I used those expanding rubber plugs to plug the hole once the two pieces were installed. Back then we just added some sealant to both halves to keep it from leaking. No idea what it was called, but installed a few over the years in the transom of my aluminum boats that did not come with a drain.
Here is the kit I use to add drains to my boat. It was just thin aluminum, so this kit worked best:
https://www.ebay.com/itm/375217811973
You put the flare part on the inside of the boat, then the spacer, then you use the flaring tool:
https://www.ebay.com/itm/1-Drain-Tu...rine-Plumbing-Replaces-520290-1-/375541547600
You really need the spacer to give the drain tube some depth for the plug to grab onto.
Also, I have found that the tool works best if you lightly grease all components, including the dies. I also add permanent sealant, as mentioned above, as I don't trust a rubber O-ring for long term service.
Once you have the kit, and it's cheap enough, you can add drains to anything, like coolers, livewells, fiberglass boats, etc. You can buy the tube by the foot.
I also use flared tubes when going through bulkheads. Good for passing fuel lines, control wires, etc. through without risking having them get cut on the aluminum over time.
A relateive cheap but very effective and permanent solution.
I hope this helps.
I hope this helps.
I assume this tool is used to flare the other end, so with the spacer on is there any part of the tube that has to be cut down so it will flare correctly?
Yes, the straight tube end needs to be cut to length. To allow for the bend radius I leave them about 1/4" longer as they stick through the hull.
At only $11 now, those flaring tools can't be beat! I remember when they were really expensive, or very few Dealers had them and would NOT loan or rent them out, so we needed to come up with our own DIY methods, like this!
