enwez
Hey guys,
I recently got my first tinny, a 1994 Alumacraft Jon Crappie Jr (1436 size). It is currently all electric with a 24v 48lb bow-mounted trolling motor and an old humminbird depth finder. I recently bought a 9.9 Honda electric start and need to wire it up. My current setup already has 2 group 27 deep cycle batteries and they are heavy! Per the manual, my outboard is made to accept a 12v signal.
So here is what confuses me... If my trolling motor is 24v then how could the depth finder be hooked up the same circuit (assuming the depth finder is 12v, and why wouldn't it be?)? He had the setup done pretty nicely and I cannot actually see any wires besides the leads that connect to the batteries (1 battery has two sets of leads and another has one- That's gotta be the key here).
Either way, I will crack open the decking and see what is going on. But it appears there must be a way the depth finder is getting a 12v signal, while the tm is getting 24v. And if so, I want to tap into the 12v for my outboard starter.
From what I read online the main reasons you should not do this are 1) interference messing with depth finder and 2) potential to drain starting battery.
But my depth finder is already on the same circuit and works fine. Also, it is a 9.9hp motor, so it should crank fairly easily even if the batteries are drained. And if they are drained, I can pull start is easily... So why not? I could save money, time, weight, and space by not having a 3rd battery...
Thoughts?
Thoughts?
