Hello there!
New to the board and very new to boat ownership! I am in the process of getting an Alumacraft 1436LT for my father to have completed by fathers day. We had always talked about one day owning a boat, waking up early and going fishing. I figured I would give him a meaningful present.
After tons of research, going back and forth between the sun dolphin 10.2 and the 1236... I decided on the 1436LT! I liked the length of the boat, allowing for more storage and design options.
I am going to be building a small front deck (where the front seat is) with a hatch for storage. A foam/wood floor. I will be surrounding the bench with wood and carpet. Installing interior lights on each of the benches and cupholders. Lastly, I will create a back hatch for a future tank placement (our motor now doesnt require a tank) and the battery along with a small amount of storage.
I have a few questions based on some of the projects I have researched on here (great help by the way!)
1). Everyone talks about giving the wood for deck framing a "water treatment". From some basic research I have done, is this simply applying epoxy on the wood to seal it? I may be using 2x4's to build the frame for each of the storage decks.
2) My other option is using aluminum tubing and aluminum angle for the front deck. I have seen people use a rivet tool to construct the frame? Is this the best way? are there any other good ways?
3) When surrounding the bench with wood and carpet. Are the wood->steel screws good to use? I know they are made to penetrate the metal then grab ahold. (I will be putting a seat pedestal ontop of the front bench and possibly the back)
4)When putting foam and wood flooring on, what is the easiest way to water seal this? I dont want to sacrifice quality for convenience, but is there an easy trick? other than applying epoxy ontop of the wood base.
Thanks everyone!
Thanks everyone!
