Have had it out the last couple of days. The rear pedestals on the front deck lean slightly backwards but it’s comfortable. Included a pic of where they were reinforced with scrap aluminum back plate. Boat fishes really good. Just need to paint and get the rest of the wiring completed. Only issue is battery box does not fit under front deck. Working towards a solution. I may look to get a dry hatch built and use angle to secure under deck.Have you had a chance to get it in the water yet to see if your front deck is level when you’re floating?
Some really easy storage to access is under the front deck of your boat. If it is similar to my Alumacraft, it is open, and not filled with foam. A quick Amazon hatch and you have an easily accessible, pretty dry area. I keep my paperwork, and bags of plastics in this area.
https://www.amazon.com/gp/product/B07Q887FF9/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
Looking at that brochure I noticed they omitted the middle bench. I love the idea of removing middle bench but have heard that bench gives needed lateral support. Any idea how they made up for that?I don't know if this will help any but Alumacraft did a 15' "Bass Pro" version in the 70's that had casting decks. I have one that is buried right now but I'll try to get some pictures of the structure for you. The brochure might give you some ideas? ALUMA-MY77-Catalog-ENUS
